bedouin
I've only owned Bedouin for 4 years, so haven't got round to completing all of the tasks on my original To Do List yet (and if/when I have it will probably be time to sell her )
My current problem is with the wiring that goes up the mast. This is not of the best, with none of the wires in question being tinned and all the connections at deck level using the old metal connectors that are not 100% waterproof.
As a result I have significant oxidisation both of the plug/socket connectors themselves and the wires, so the connection is intermittent at best.
I suspect the only really satisfactory solution is to replace the lot - which leads to three questions
(i) Given that I would rather put this off until the next time I have the mast down, is there any feasible way to clean up the oxidation to improve the contact in the interim? (Brasso does a good job on the pins of the plug, but is less use on the socket and none at all on the wires
(ii) When I get round to replacing the connectors are any of the modern ones better than the old metal ones I have now?
(iii) is SWR a reliable way of measuring the quality of the VHF connection (for that matter is it likely that VHF will couple capacititively across a poor DC connection)
