William_H
The saddler 25 has I believe a mast head rig. The middle of the mast is I imagine located by intermediate shrouds whose chain plates are aft of abeam the mast so in tensioning they pull the middle aft. This pull aft is usually countered by either one intermediate or baby forestay to an attachment middle of foredeck, or 2 intermediate side/forestays going to chain plates forward of abeam the mast. Now regardless of setting intermediate shroud tension to a percentage of breaking strain it is the relative tensions of the stays pulling the middle forward or back that determine the bend of the mast. So bend aft at spreaders means intermediate stays are too tight or the forward pulling stays are too loose. (it is not just the tension of the stays that determine the pull on the middle of the mast but the distance fore and aft of abeam the mast of the attachments)
So forget the tension gauge and just adjust the intermediate stays to get the mast straight or slightly middle forward bend.
In some rigs (often fractional) probably not yours, they use aft swept spreaders as a means to push middle of mast forward. This relies on the angle of the spreaders aft and the tension of the cap shrouds o provide push forward. In practice then the only way to get the mast bend forward middle is to ease the tension of the intermediate side stays (which pull it back). ol'will
