Portofino
With a few recent threads about s Onan ,s heat exchangers scaling up leading to overheats and shutdowns I thought to share an alternative method .
Seems trouble free from a scale POV .
How they get around it.It is air cooled .
The engine cylinder is finned like a VW beetle engine or older BMW motorbike R1000 type
So no need for sea water engine coolant HE , as no engine coolant to exchange heat in the 1st place .
No need for sea water to ever see the engine or windings of the geny bit .
Instead they have a seawater air HE , which just looks like a mini car radiator .
Here seawater is pumped through and air sucked by a fan through it ( from under the bilge ) to cool it then sucked across the windings fins then the engine cylinder fins the out .
There’s a few cowls to direct the air and the box has to be pretty sealed so s not to cock up the air flow .
When it’s turned off there’s just seawater at seawater temp left in the HE , - crucially no hot engine circuit coolant to “ bake “ on the salt - so the HE never actually clogs up .
Just needs a pencil anode every now and again .
Very simple .
You could argue they are noisey ,but they are in a so called sound box .
They do small genys with the seawater / air some medium and will build to customer requirements .
They also do conventional HE - seawater / engine coolant
Just seems like a neat solution to proverbial salting up of HE,s
This ones a 2002 modal still going strong , there not a lot left to go wrong once the seawater s taken out of the equation.
Engines are either Yanmar or Kubota - so no change there
https://imgur.com/a/VEq7YOU
Very simple .
