Marseille to Torrevieja. Wish us luck.
Bit of both. We’ve got the Torrevieja berth from the 1st. We’re planning on enjoying the journey and dodging the weather.
Might stop at Empriabrava tonight just to see what bits have broken so far.
Open to suggestions 😎
Whatever hapens, if you see a ST34 either go WOT, or scuttle the boat . Do not approach, you can tell the boat !! he flies his g string and sketchers, at half mast. You motor at night or in a force 2 , as he does neither .
Once on the Spanish side, if you need to "dive for cover" - it might be worth having Port d'Aro on your list. Initially, on entering, it doesn't look big enough but right at the end of the marina there are large berths big enough for you - we squeezed in.
Might be worth a stop anyway.
See this video
And, of course there is Sant Carles on the way if you want a fully English speaking marina with services and local town - also fuel available 24/7.
Thanks everyone.
So, day 1…
Get boarded by French customs. All ok but did ask for VAT paperwork.
Gulf de Lion a bit lumpy at first but better later.
About half way across all the electrics beeped and went out. Seems the alternator doesn’t charge the house batteries. Quite scary 60 miles from shore. Luckily the generator started and recharged them.
Got to Empuriabrava just now. Ropes supplied with the boat are all a bit short so we have a bit of a leap from passarell to shore.
Need a beer 😄
Thanks everyone.
So, day 1…
Need a beer 😄
A coincidence. I helped with a delivery from the SoF to Sant Carles and half way across the Gulf de Lion, the engines overheat alarms came on so I can understand you getting scared. Our problem was that the water intakes are scoops so the solution to our overheat problem was "to go faster".
Anyway, thats probably the most worrying part of your trip done.
The other place where you will probably leave the sight of land is crossing Valencia Bay. The only thing to watch out for there is the Columbrettes - volcanic islands but not very large and easily seen on the charts.
Enjoy your delivery trip - don't go too fast - enjoy the places on the way.
