marinising standard car diesels
Den
30 Mar 2003
I am looking for information/literature on how to go about installing a 'converted' engine and sterndrive configuration into my Norman 20.
My thanks to Gordon for his offer to 'talk me through it', and to all others , especially about how to 'post' a topic!
Thanks ,
Den Moran
BarryH
31 Oct 2001
Surrey
Probably the easiest engine to work with would be the ford xld. Loads of "kits" and bits around for it. I did have an article in one of the mags, but I don't know what I did with it.
Its not cheap though. All the bits and pieces will probably set you back 600-800 quid and thats without buying the engine to convert and any work that may be required. Give Forbsie a call, he's wrestling with one at the moment.
Forbsie
9 Mar 2002
Hi Den.
Congrats on getting the thread up and running. I'm in the middle of marinising a Ford Escort 1.6 diesel (XLD416) to be attached to a Sonic 100 Outdrive. I've been sort of at it for months but keep chickening out coz I've never done the mechanical bits before. I'm hoping to have it finished by next week though. My kit cost me £1100 from ASAP but there will probably be stuff that I won't install, so yours should be less than this. The article that Barry talked about, he lent it to me but Boat Mart did a re-print of it last year, so either one of us can lend you that once I finish mine. With a bit of mechanical nouse, you can probably marinise an engine in a couple of days as opposed to my 6 months or so.
PM me with details of where you are and a phone number and I'm sure that we can offer lots of advice.
Gordon
<hr width=100% size=1><A target="_blank" HREF=http://www.arweb.co.uk/argallery/forbsie?&page=1>My Project</A>
30 May 2001
Upper Thames
Try www.lancingmarine.com
They specialise in this kind of thing.
Other engine to consider is the old favourites - BMC 1.5/1.8 (Sherpa) or Perkins 4108 as these are cheap to pick up secondhand and will fit quite nicely into a Norman.
Due to the weight, you wont get much bigger than a 1.7Litre in there without a seriously low transom in the water.
Mike
Den
30 Mar 2003
Thanks Gordon,
I'm getting the hang of this now! Its really good of you to take the time and trouble-I must admit I could do with a wetnurse on this one!
The main problem is that I have a semi-displacement hull, and want to have a good match of engine type and stern drive. I am inclining towards Ford because of their availability and spares prices etc., and have taken note that you have one from an 'escort'. What other ford engines are suitable - to rate between 30-50 hop?
I am in Swansea, and my tel. no. is 01792-781904
Kind regards,
Den Moran
Den
30 Mar 2003
Thanks |Mike,
I was looking for a BMC, but as I said to Gordon, I am thinking about a Ford now, any info on where to buy one-Ex& mart maybe, or a good recon place?
Thanks Den
BarryH
31 Oct 2001
Surrey
For the size and weight, the little ford will be just fine in the Norman. I think thy're rated at about 60hp anyway. The only problem I can see with using any of the other ford lumps is the size of the things. You could if you wanted a bit more power go the FSD transit route. But as with all these things the bigger you go the more its going to cost. The transit engine will give you around 75-100hp. Then you've got to look at the outdrive. Lancing will do various adapters to fit a lot of the volvo drives etc, or you can use the enfield, sonic.
What sort of use will you want out of the boat. Inland rivery stuff or coastal work?
Forbsie
9 Mar 2002
Or I could do you a deal on a 2.1 Ford Sierra engine already marinised.
OH MY GOD!!!!!
It's 02.15 in the morning!!!!!
I think I've turned into......................
.........BYRON!!!
Den
30 Mar 2003
Oh temptation! Whats the deal with the Sierra engine?!!
I wonder if thats too heavy for my 20' Norman-please advise! Or is it much the same size as the escort engine? Can it link to a Sonic or Enfield OK? etc,etc Most of all-what are you asking!!! Tel.01792-781904
Thanks,
Den
Den
30 Mar 2003
I am going to do the through Europe trip -Rhine-Danube Aegean,MedRhone,UK. This is why I want areliable unit/power train. If it was just Western approaches I could use a Mariner outboard for jollying locally!
brianrunyard
30 May 2001
Poole, Dorset. UK
homepage.ntlworld.com
I enquired at the local car breakers, a good condition Ford 1.6XLD costs about £350. Lancing do a full marinising kit for £590 plus about £200 for the adapter to match your drive. Go for one out of a relatively low mileage crashed vehicle.
This engine was used in plenty of small Ford cars and vans.
I don't know the reason but several people on this forum prefer the 1.6XLD to the later 1.8XLD, something to do with relianility I think.
<hr width=100% size=1>Brian
http://homepage.ntlworld.com/brunyard
Den
30 Mar 2003
Thanks Brian,
Thats really helpful information, I will start asking around locally,
Den
Den
30 Mar 2003
Gordon,
Have you found that article yet,please?
I'm decided on a Ford 1.6 with an Enfield,but am still gathering all info before making the final decision. How are you getting on with yours?
If you want to conTact me directly, my e add. is morandenis@aol.com
Thanks,
Den Moran
Forbsie
9 Mar 2002
Hi Den.
Sorry for the delay but I hope to be finished and ready for starting it up this week at which stage I'll send you the magazine. A lot of the photos have been printed back-to-front, so I'll also take some pictures of the completed engine and e-mail them to you.
