ianfr
What's the best way to flush after use? Ours doesn't have a port to attach a hose which some seem to have. Anyone use Muffs successfully and if so which one do you use ?
TIA
TIA
I doubt if you will find muffs to fit.What's the best way to flush after use? Ours doesn't have a port to attach a hose which some seem to have. Anyone use Muffs successfully and if so which one do you use ?
TIA
As the good attachment mentioned, it's not possible with a rotating prop. I've the Tohatsu variant of the OP's, with a constantly running prop, otherwise I'd buy your item! The wheelie bin I use was a present from my wife, specifically for this very aged, 5th hand (at least) engine, and is perfect.You might find this one useful. I use it regularly. Outboard motor fresh water flush
Take the prop off.As the good attachment mentioned, it's not possible with a rotating prop. I've the Tohatsu variant of the OP's, with a constantly running prop, otherwise I'd buy your item! The wheelie bin I use was a present from my wife, specifically for this very aged, 5th hand (at least) engine, and is perfect.
That looks a possibility ?You might find this one useful. I use it regularly. Outboard motor fresh water flush
Not quite the same as I didnt have an old fender to sacrifice but this worked.As the good attachment mentioned, it's not possible with a rotating prop. I've the Tohatsu variant of the OP's, with a constantly running prop, otherwise I'd buy your item! The wheelie bin I use was a present from my wife, specifically for this very aged, 5th hand (at least) engine, and is perfect.
more importantly filling a large container with fresh water is usually not practical on a boat! Most boats will have a bucket big enough for a small engine, but lack the means to fill itThanks guys, I was thinking of flushing aboard or on return to home port. Large containers or wheelie bins are not practical on the boat.
