Portofino
It gets up and lifts out at about 18/20 knots .Does not feel right but works between 20-25 Its planning like any other .R U for real?
Now deep vee boats, on top of not rolling at anchor, are also fuel efficient?
Poweryachtblog, would you mind telling us something about that?
How ever shove the sticks up further and it lifts like a second time stiffens really up and has like a second burst of acceleration.
Whats happening from what I have deduced yard walking looking at others is the chine flats at the rear are excessively wide and the lifting strips or you may call them spray rails Fwds but they morph extra wide as they tail rewards the stern so in effect add further lift .
The rudders in this 2 nd phase become pretty useless because they lift too far up leaving just the tiny in effective tips in .
Deep V all 23 degrees of deadrise has been lifted .
Any theoretical drag ( you are correct ) has reduced = hence you don’t loose out mpg wise ……you do at 25 knot under , and you can steer it better.
To stop it bow steering the V is actually attenuated by a round rather flat ish bell shaped keel , they call it a lifting pad .
So in my case the 23 degree dead rise is mixed with extra wide chine flats , extra wide spray rails going to the transom morphing in to lifting strips and where the two side meet at the keel a round bell shaped pretty flat ,Union not sharp knife edge .
This add to the ride comfort mostly , arrow like directional stability and reduces drag the extra lift .
That drag reduction can be harvested in two ways .
1- reduced rpm and fuel consumption……PYB s point .
2- higher top speed leave it .
The drag reduction must have been on Amarti mind designing this rudder system .Show me this by another manufacturer Mapish .
Note that extra wide strip twixt flap bathing platforms support Rhs of the hull .
