Mainsheet track - how do bend?
Talulah
27 Feb 2004
West London/Gosport
One of the stops that fit onto the mainsheet track and prevents the traveller from moving has broken.
I bought a replacement pair but what should have been a 10 minute job isn't. They don't fit. The 'I' section of the track is not the same for the old stopper as the new stopper. Rats.
Now I could try machining the stoppers to get them to fit but I don't have the facilities.
Another option is to replace the track.
The track is curved to fit the back edge of the cockpit.
How or where would I get the track bent to match the existing?
Many thanks in advance.
gardenshed
1 Jan 2006
13:44:00N 100:32:00E
When you buy the track (even from on-line suppliers) you are usually asked what bend you need in the track so you shouldn't have a problem.
The couriers then add their own little twist (or bend) to the finished product........
simonfraser
13 Mar 2004
i'd get the stoppers machined, replace the track and the bolts won't come out, holes in the wrong place, the ends now in a slightly different place so it looks naff, etc. . . . oh and the traveller might not fit / run so well, you'll only find that out in a blow when it's all fixed and done :-((
