charles_reed
Having fitted a new, stronger, taller and generally more adequate mast - I, in a rash fit of enthusiasm, got Jeremy to make me a new fully battened main with an aggressive a roach as you see on Open 60s and Farr 52s.
With the old main on the boat goes like the clappers - but the poor thing looks a bit shrunk.
Unfortunatley the new main overlaps the single standing backstay by 40 mm on the top batten 150mm on the 2nd batten and 65mm on the 3rd batten.
I've had a number of recommendations, some half-baked and some quite good.
These range from:-
1. Cutting 200mm off the foot (Cariad Voiles)
2. Taking off the roach (lots of neurotic yotties)
3. Fitting twin running backstays, I've a two panel rig with 22 deg on spreaders, (Bernard Bossé & other dedicated go-faster freaks)
4. Fitting a single-line, 2:1 purchase reef just above the cunningham, which should give just enough clearance to allow the roach to clear the backstay.
I've already got 4 reefing points on the main and only 3 sets of in-boom leech lines.
The elliptical tip of extra roach, apart from increasing the efficiency of the main by about 28%, gives me an additional 18% of area for those nauseating light air conditions one suffers in the Med
Now what suggestions would the august,learned and experienced readers of this BB like to make and what solution would they recommend.
These range from:-
