lowrance problems
scubajohn
18 Dec 2012
shropshire
my lowrance gps 5000300 and fishfinder x515 intermitantly cuts out i reset, the gps takes ages to track properly as a virgin newbie any help would be aprecaited
This sounds like a loose connection between GPS Antenna and the screen device /or the Power to the GPS antenna -
What you will find is a cable (4 wire) - two wires are basically connected to the Screen and the other two are the power to the GPS antenna (directly connected to +12V battery).
What I would suggest is to turn on the device, and then play with the cable and see if what you just described happens or not - and then connect all connections correctly.
