I have a Volvo MD7A 13 HP 2 Cylinder Diesel 1981 Vintage..
Over the last couple of season I have had a problem will low oil pressure alarming at tick over when the engine has been used for more than about 20 minutes.
A slight increase in throttle in neutral will stop the alarm…..
I started by replacing the sensor, which did not solve the problem. I then fitted an oil pressure gauge that showed that when under load the engine runs at approx. 40psi, but drops off to less than 10 when ticking over.
After some advise and a lot of discussions a friend and I decided to bring the engine into the cabin, turn it over, remove the sump, and replace the oil pressure relief valve. This was done over last winter.
The problem has reoccurred this season.
My next ideas are to:
1. Change the oil from the standard Volvo recommendation (15W40 I think) to something that stays thicker at higher temp, but I have no idea what to use.
2. Increase the tick over slightly.
3. Ignore the problem!
Any ideas or suggestions would be gratefully received.
Happy Sailing
Andrew Trayfoot
Happy Sailing
Andrew Trayfoot
