JollyRodgers
Just when you think you get your boat 'perfect' something goes wrong .. Atleast I'm never bored anymore..
Anyway, was sleeping down on the boat the other week. Usually I disconnect from shorepower when I leave, plug in a small solar panel (I imagine it is something like this; http://www.amazon.co.uk/Solar-Batte...1441095841&sr=8-22&keywords=solar+panel+boats but cant be sure without checking next time I am down) and then turn off the batteries.
This time the solar panel wasnt plugged in properly and therefore was not keeping the batteries on trickle charge whilst I was away. I came back to the boat, and connected shorepower and even then the batteries were slowly dying and when they dropped below around 10V , the fridge turned off and wouldnt start up. We wanted to go out for a little sail, but couldnt start up the engine - which is when we found out the batteries were flat. I was hoping that the engine starting up would give some life to the batteries - but did not.
I also hoped that being connected to the shore power would charge up the batteries - but that did not.
When I left the boat, I had the batteries turned off and solar panel plugged in and shorepower disconnected. Hopefully when I go down on Friday they will be a little higher up.
The batteries are around 6 years old and on the survey when I bought the boat she said that they were old and would need replacing soon and were only just showing 11-12V, which was low. The owner said he had to switch to Batteries 1 and 2 to start up the boat and it was always fine.
I have 3 batteries on board. They are Exide PP75 / 75Ahr.
Does it sound like the batteries are just knackered and I will need 3 new ones? If so, what would be best? I presume that the batteries I have on at the moment are low-end/budget ones.
Questions:
1) How come shore power doesnt charge up my batteries.
2) How come my fridge stopped working, despite being connected to shore power? Surely it runs directly through to the shore? How does that work?
3) What "volts" should my batteries ideally be at, 12-15V?
I also had an issue with my engine running when I took the boat out a couple of months ago. It was running along fine and then all of a sudden (without any spluttering or anything) it just cut out silently. Could there be a correlation between this and the batteries being in poor health? I posted about that a while ago and people seemed to think it couldve just been an air bubble or something going through and not a big deal. I managed to start up the engine after a 10 second pause and it ran okay after that.
Many thanks,
Alex
Sorry the pics are big and the boat is dirty. Haven't refurbed these areas yet
Battery 1 Health
Battery 2 Health
Batteries 1, 2 and 3
Questions:
Many thanks,
Alex
Battery 1 Health
Battery 2 Health
