MontyMariner
Good goingwe managed to sail all but an hour the 60 nm .
Thanks for that , I appreciate your comment and everyone else too ,Your maximum sailing speed is going to be limited by wave drag rather than skin friction so it’s quite possible to have enough power under sail to overcome the effect of fouling but be limited by “hull speed”. Under engine you have much less power and are more likely to see the effect of skin friction. You have eliminated power development and prop problems so drag is the only other variable.
Once again thanks for your comment .I've just been through re-propping my boat, changing from fixed to folding.
Look at it this way:
There are several factors:
The thrust needed to drive the boat at a certain speed
The prop
The engine turning the prop.
The engine seems to be turning the prop OK.
The drag of the boat doesn't seem too bad as it sails OK.
So it sounds like there is something wrong with the prop.
I would be checking that the prop opens fully, is put together right, hasn't got something wrapped around it etc.
We had something a bit similar on Sigma once, a tangle of rope on the prop stopped it opening properly.
The prop was taking power from the engine, just not very efficient at giving thrust to drive the boat.
That's assuming it's the same prop which used to drive the boat OK.
The other thing is, to be sure it's not the hull fouling, you ideally need to see the boat sailing close hauled in F2 or F3. Or at least close hauled.
Sailing free in a good breeze you can tow another boat and only lose half a knot.
At the moment it’s all a guessing game as said until I can dry out I won’t know if there a problem with the prop,I'm struggling to imagine how the key failing won't allow the prop to unscrew the nut and fall off?
And I can't see how the prop would spin on the shaft so steadily? It would need a constant level of friction between prop and shaft so the engine revs and prop revs keep steady at a given RPM?
Only thing I can think of is the nut has been tightened onto the end of the shaft, it's reached the end of the thread before pushing the prop firmly onto the taper?
Has a washer or spacer been lost or left out?
Once the proper is properly tightened onto the taper, the key should be idle, it's really there to hold things still while you get the nut done up.
When you undo the nut, the taper should have enough grip that you need an extractor and maybe to heat up the prop boss, to remove the prop.
The prop I bought for my boat needed a spacer washer to work, because the internal taper in the prop boss was shorter than the taper on the shaft.
Maybe your prop is marginal. maybe a washer is out of place or something?
If the prop is spinning on the shaft at all I would be worried the nut will come undone one day soon!
That would mean you lose the prop.
We will see to day Nick still in my bunk after a late night .good luck in your quest. I hope your boat speed improves, but if not im sure we can suggest some more things to check!
It’s been a bad year for fouling here in the solent, maybe weather patterns?We will see to day Nick still in my bunk after a late night .
before drying out I would had sworn it wasn’t a fouling problem mainly because the boat not been launch that long and been on the move other then 10 days when it sat in a marina in Denmark .
but reading a few people blog we know who are also in Denmark and they too seen to be having fouling problems .
So we see.
Actually it's quite a relief, I started to think we was imaging the speed we did before I worked on the mounts.I’m lucky if o can motor at 3.5 when my hull is a bit fouled
Yes on the keel and on the bottomSo, was it the fouling on the leading edges?
Ian if you read all the posting you see that I myself did think it was something to go with the work I did on the mounts even tho talking to Volvo engineer after I ran out of ideas assured me it would have nothing to do with the work I did .I did wonder whether your shaft seal is of the type using a jubilee clamp that may have been over-tightened on the prop- shaft to prevent water ingress
However, it seems that that fouling is the culprit, on the keel. but all previous ideas were based on removal of shaft and engine works.
Ianat182
