Graham_Wright
I experienced a couple of little problems during this week’s trip. I found my big alternator, although outputting 14.2 volts, was not charging the domestic batteries. The alternator is not grounded through the frame and the 0v connection to the main ground via a stud was losing 5volts due to a loose nut.
The second similar problem was at the starter motor solenoid 12 volt connection which is shared between the battery direct + output and the alternator (different standard one) as on a vehicle system. A resistive connection here generates heat and, in my case, a fairly serious fire with flames requiring two CO2 extinguishers, copious amounts of water and a lifeboat tow.
Hence - check your nuts!
