geem
There may be some major differences in how your light catamaran with small hp behaves compared to a heavy monohull with lots of HP and momentum.The issue with a reliance on momentum or the monetum developed in a gust is that though the energy is transferred to the snubber - its transitory.
The gust develops, the yachts moves back, the catenary flattens and the snubber stretches - but the gust then dies and the yacht moves forward. If we recall Panope's video of the moving anchor - it is moving slowly and a transitory gust is not going to have much impact. The gust also needs to develop more tension in the rode than the previous gust - or the anchor will not move, at all (unless there is some other effect - like twitching). It is the same if the yacht reverses up - the combined potential energy of the flattening catenary and the stretching snubber increases and then becomes greater than the energy available from the engine - the yacht slows and stops and is then pulled forward by the release of the potential energy in the rode. Its transitory
Your bogged vehicle is not similar to our situations. The bogged vehicle will normally have its engine running, the pull out vehicle backs up and at some point applies the brakes and becomes a fixed point, or keeps reversing - the bogged vehicle then enjoys the transfer of energy to them, through the snatch strap and in addition runs forward in gear. If the pull vehicle is not held stationary nor continues to reveres, away from the bogged vehicle, the bogged vehicle will stay where it is.
To set an anchor needs a long steady pull, with increasing tension as the anchor dives, again think of the Penope videos, how long he 'sets' the anchors - yet they are still moving. You can only use a yacht as you do a pull out vehicle if you can hold the yacht stationary and allow the potential energy in the rode to impact the anchor - not possible - except for a few seconds.
The advantage of backing up slowly and straightening the catenary is that the engine will commonly be able to hold the yacht stationary. at 3:1. Unless you have deployed too much rode, or you carry too large linked chain and assuming you are not anchoring in 30m - then you can flatten the catenary and the engine can be run with the yacht stationary and you then do not have a transitory tension - it can be sustained. Not so with a snubber as it will continue to stretch and stretch - and then it and the catenary will pull the yacht forward. You could of course repetitively attack the anchor going back and forth - but the seabed will each time resist movement (it needs time) and as you increase the cyclical loading of the snubber - its life gets shorter.
An illustration of the time needed. Your anchor is well set, you are to leave, you shorten up the rode until it is vertical and then you sit and wait, and wait and wait - for the anchor to break out. The seabed does not react to a transitory tension - it needs time. This retrieval process is commonly advised - but the patience required is less than that to set an anchor as when you retreive you have a lever, the shank, acting on the fluke.
The final rule is one we all know - if something on a yacht is to go pear shaped it will happen at the most inconvenient time. Just read the article on the Med storm. Their Witchard hook was fine - until it wasn't . Ground tackle does not fail if you are pottering about - it fails when the wind is singing and the chop is concerning.
I too have been critical of the Panope tests and my comments, intended as being supportive, have been ignored and unanswered. However his moving anchor has been informative. A well known anchor maker suffered the same issue - they respond to their problems by removing the offending video. I, or course, never thought they would remove the vid - so did not save it.
Setting an anchor deeply and removing from a deep set demand both tension and time at tension, as Panope demonstrates and as you demonstrate to yourself every time you retrieve a deep set anchor. High tension might be wasted if it is transitory (think Panope) or your bow roller and windlass at retrieval.
Take care, stay safe
Jonathan.
I don't recognise the transitory aspect you mention. If we pull back hard but progressively on our anchor with the snubber attached we load up the anchor and it drives deeper in to the bottom. If we do that in a serious of jerks it will inch its way deeper. You seem to be assuming that a snubber has no elastic limit. It's basic physics. They do. Your snubbers may behave differently to mine. I don't use climbing rope. I use nylon three strand. It's exactly the same rope as I used to use in vehicle recovery. Known as KERR. Our 19t boat simply does not bounce at the end of a loaded snubber as you describe.
If I build revs slowly, we pull the snubber into its elastic limit. At this point it behaves like chain. Your experience sounds like your boat is not capable of doing this due to a different kind of rope and lack of engine/ prop power. For the avoidance of doubt, our 12m long snubber stretches such that we never feel and gusts or movement of the boat at anchor. I suspect it doesn't stretch in the way your climbing ropes do.
I have happened to be snorkeling around the anchor in a sand/broken coral seabed. I shouted to my wife that the anchor wasn't well set. I asked her to give the chain a pull. This is with the snubber set. The boat is moving backwards as I am snorkeling. My wife hasn't built the revs up slowly she just put the boat in reverse so the load came on the anchor as a snatch with boat momentum. I watched the anchor set deeper. It was only about three seconds of hard load but the anchor dug deeper. It was an unusually hard bottom. I asked her to do the same again and the anchor again inched deeper. I realised in that hard bottom it wasn't going to set any deeper so I left it at that.
We use a short length of dyneema as a back up to the snubber should it fail. This dyneema is permanently fixed to the clear on the windlass. It it simply tied through a link on the chain forward of the windlass. I have no concerns about anchor load being taken on the windlass case. The windlass weighs 55kg. Its mounted on M10 bolts through solid deck with 2" teak reinforcement and a s/s angle fixed below deck through the rear fixing bolts. It's super strong.
With regard to Panopes videos. Only certain anchors were still moving. Good anchors set quickly within their own length. Our experience of anchoring here in the Caribbean is that a nicely set anchor will often disappear completely if we have been anchored for a few days in gusty/ breezy conditions. This is happening with the snubber set. It's no different to power setting with the snubber set from what I can see. Even a short duration high pulling load on the anchor will have some movement effect. Lots of these will move an anchor deeper if the force is high enough until the anchor develops sufficient hold and depth to no longer move.
The only failure we have experienced other than a snubber failing a few years ago, is with the Terrible Wichard Hook. The pin sized. It's now bin material.
To recover a deeply set anchor we simply haul the chain tight until the chain is vertical and motor forward. It never fails to break out.
We are currently in Bonaire in the ABC islands of Venezuela. It's a marine park so first time we are not at anchor in many months. A quick anchor survey since everybody's anchors are on show. 20 Rocna, 2 Spade, 2 Mantus, 1 CQR, 1 Danforth, 5 Delta. All these boats are either European, Canadian or US flagged. Rocna seem to have cornered the market very successfully
