smb
Further to my post a few days ago (thanks for all the replies) I have concluded that it is indeed me, or more specifically my receiver. The question is what to do about it.
I have contacted Nasa. Apparently their key engineers are on holiday at present but they offered to have a look at it if I return the complete setup. I am grateful for that but a) have an imminent 2 week break and b) I am reluctant to remove the headlining etc neccessary to extricate the antenna lead, so I have monitored the performance and done some rudimentary fault finding but quickly come to the limit of my knowledge.
The story so far:-
Nasa Target Pro Plus, the model with the inline switch for local/international frequency, approx 3 years old.
About 6 weeks ago stopped receiving local forecasts.
Check with forumites confirmed signals are still active in the Solent.
Programmed to receive all stations and all reports.
When switched to local, still receive international signals but not Local.
Checked all connections and all seem OK, both physically and continuity.
Looking at the circuit board in the switch box the red and shield from the antenna are wired direct to the core and the shield of the coax respectively, while using a circuit tester I found that the blue wire from the antenna is linked to the shield of the coax when the switch is in the local position. None of this wiring (apart from the shield to shield connection) was what I expected, but then I have almost no knowledge of radio signals and how they work so would welcome any advice.
Steve
The story so far:-
Steve
