DangerousPirate
So I got this little wind generator/turbine at the back of the boat, and the cable seems to have been connected at some point once. It is just a weird one because whenever I look up configurations for charge controllers it aways shows 3 cables going in, and then theyre being converted and directed to the battery. Though in my case the direct cables from the wind turbine are only a red and a black (positive and a negative) on a luster clamp, and I dont know what it was connected to.
So how do I connect it to a charge controller if its AC? I dont have the three cables that you normally would connect. And as far as I understand I cant just use a solar charge controller (because of the dump load).
Unfortunately I dont know what brand or type the wind turbine is. It would be a nice addition to the solar panels, not to mention that its already installed and the cables pulled through the boat.
Does anyone have a similar set up and can tell me what I need to do?
