Chiara’s slave
And LiPO4 is a factory option on the 40.
I have no connection to this guy Clark's Adventure and cannot vouch for him in any way but his videos vis a vis LiFePO4 batteries make sense to me without appearing to be snake oil sales. If you look through his Youtube "catalogue" you will find reviews of pre-built battery packs but there is no reason why any reasonably handy person couldn't build his/her own battery from individual prismatic cells and an appropriate BMS (Battery Management System) board. Clark has developed a monitoring device he calls the Bank Manager which switches off/on battery bank charging when it detects the point of full charge or a drop in charge below a set threshold and he promotes the thing in his videos but he does explain, in layman's terms, why he developed it. He responds to email enquiries via his website but probably won't offer more than general advice to someone who is not a customer. I would have no problem doing a LiFePO4 switch on our boat based on the information I've gleaned from his videos coupled with my research of other sources....It seems that I would be well advised to ensure a professional installation. I made inquiries. A pro rewire, at least in part, is indicated - and I'm not averse to that, but the pros I've contacted are. I was told by a well-known pro installer that 'it wasn't worthwhile' for my purposes. And I'd likely still need to retain an AGM LA unit for engine starts, with associated charging facility.
The other important 'gotcha' which has emerged through posts above is a marked reluctance by insurers. That is significant.
I've tackled many DIY jobs with good success, and will happily replace electrical items that are 'mechanical' in nature - e.g. running cabling, mounting switch panels, substituting this for that - but a DIY change to a wholly sound LiFePO4 system is 'a bridge too far'.
Any better ideas?
From many perspectives makes sense. But let’s hope they informed their insurers and they are happy to continue cover.A guy on the South Coast Dragonfly group has just had his DF28 converted to electric propulsion, he has 17Kwh of battery. I think most of us here are insured through the same broker as most of us knew him sailing beach cats years ago. He has one of these bad boys in each outrigger.
Did tou manage to get either or both of the marine electricians to formally issue a certificate / letter “signing off” your installation?I had the exchange below with Pants. As ever, they are eminently sensible. Bottom line is if I have screwed up anything, to do with any part of the boat, I expect a claim to be ‘complicated’ - the policy conditions are “more like guidelines”.
Having done the install myself with the invaluable advice on here, and having had the installation checked and OKed by two marine electricians, I am confident that with the install and the inherent safety of LifePo it is low down on the list of things I need to worry about.
Insurer:
“We confirm receipt of your email of 04.01.2024, the details of which have been noted.
We advise that the details you have described are acceptable provided the installation is signed off by a qualified marine electrician.
We take this opportunity to wish you a Happy New Year and all the best for 2024.”
There is no certificate. There is nothing to certificate because there is no standard.Did tou manage to get either or both of the marine electricians to formally issue a certificate / letter “signing off” your installation?
That seems to be the tricky bit (unless can use personal contacts to enable).
I think it's a work in progress by some marine insurance. A lot doesn't make sense and wording is not precise.Y'see?
Squeeze a little and lots more useful information comes out - like toothpaste!
Insurers have years of experience of hundreds of thousands of LA installations on boat - which don't catch fir. Fire is extremely rare on boats and is almost always either gas related or on petrol fuelled boats during refuelling. There are virtually no reliable statistics in the UK on the subject other than RNLI/Coastguard and occasionally reports from insurers of main source of claims. Fire does not appear in either of them as significant. Much better statistics in the us where reporting such incidents is compulsory, but obvious that the main issue is with petrol powered speedboats of which there are rather a lot mostly used by dickheads.Just like there is no certificate for a lead acid intallation. But lead acid doesn’t catch fire, does it. Ask a submariner.
He claims (as of 28/09/2024, so fairly recently) that other available big name charge contollers (Victron is mentioned) arent correctly optimised for charging Lithium (specifically they charge to a reference voltage) and their use will reduce battery lifespan.I have no connection to this guy Clark's Adventure and cannot vouch for him in any way but his videos vis a vis LiFePO4 batteries make sense to me without appearing to be snake oil sales. If you look through his Youtube "catalogue" you will find reviews of pre-built battery packs but there is no reason why any reasonably handy person couldn't build his/her own battery from individual prismatic cells and an appropriate BMS (Battery Management System) board. Clark has developed a monitoring device he calls the Bank Manager which switches off/on battery bank charging when it detects the point of full charge or a drop in charge below a set threshold and he promotes the thing in his videos but he does explain, in layman's terms, why he developed it. He responds to email enquiries via his website but probably won't offer more than general advice to someone who is not a customer. I would have no problem doing a LiFePO4 switch on our boat based on the information I've gleaned from his videos coupled with my research of other sources.
The insurance cover issue is not a problem in my case because I haven't found a company that is prepared to insure our 61 year old girl. I can only imagine that as underwriters better comprehend the differences in lithium battery chemistry they will cast a more favourable eye on LiFePO4.
Not much chance of restricting dickhead insurance. Too important a market demographic.Insurers have years of experience of hundreds of thousands of LA installations on boat - which don't catch fir. Fire is extremely rare on boats and is almost always either gas related or on petrol fuelled boats during refuelling. There are virtually no reliable statistics in the UK on the subject other than RNLI/Coastguard and occasionally reports from insurers of main source of claims. Fire does not appear in either of them as significant. Much better statistics in the us where reporting such incidents is compulsory, but obvious that the main issue is with petrol powered speedboats of which there are rather a lot mostly used by dickheads.
Well exactly. Once a significant number of us have installed lithium batteries, insurers will have the numbers, and all will be fine. We destroyed a lead acid battery on Wednesday. No fire, but it puffed up, and broke it’s casing. A 12ah one for a bilge pump on a dayboat. Took it home and charged it overnight, the charger was set on high and I didn’t notice, being knackered. You can destroy anything with only a little stupidity.Insurers have years of experience of hundreds of thousands of LA installations on boat - which don't catch fir. Fire is extremely rare on boats and is almost always either gas related or on petrol fuelled boats during refuelling. There are virtually no reliable statistics in the UK on the subject other than RNLI/Coastguard and occasionally reports from insurers of main source of claims. Fire does not appear in either of them as significant. Much better statistics in the us where reporting such incidents is compulsory, but obvious that the main issue is with petrol powered speedboats of which there are rather a lot mostly used by dickheads.
Funny you should mention those two companies. The surveyor I used recently suggested I stay well clear of those two companies. He was less than impressed with dealing with both of them.Not true. Restrictions on charging lithium batteries specifically mentioned in Bishop Skinner and GJW policies. No restrictions on any other battery types mentioned. No need to ask, only read. Your policy may be different.
Indeed. Fortunately not such a big problem in the UK and there are relatively few petrol speedboats and most seem to be used sensibly.Not much chance of restricting dickhead insurance. Too important a market demographic.
Agree broadly with your sentiments about surveyors and insurers (although have had excellent service from both the insurers cited). Surveyors get into arguments with insurers and often lose and maybe that colours their vision as the vast majority of claims are met without ever involving an independent surveyor. Positions based on ignorance are very difficult to shift.Funny you should mention those two companies. The surveyor I used recently suggested I stay well clear of those two companies. He was less than impressed with dealing with both of them.
One thing I have learnt in the last 2 years of working on a commercial lithium battery project is how uneducated most surveyors and insurers are. The insurance and marine surveying industry has seen 90 major fires associated with lithium in a 12 month period. None of these fires have been attributed to lifepo4 chemistry, (as fitted to yachts as domestic battery banks.) the problem is that the average surveyor and insurance underwriter don't know the difference.
The 90 fires worldwide, have been caused by lithium powered toys being charged on super yachts. When the insurance and surveying world finally get their act together, I am sure lifepo4 battery installations will be the norm and fully accepted. Until then, there are insurers to stay clear of. If all boaters voted with their feet and explained why they were moving insurer, they may have a change of view
