MagicalArmchair
Morning all,
I am replacing the diaphragm of my Volvo Penta Saildrive from my D2-55 and rather than supporting the back of the engine and wiggling it forwards (as it says to do in the guide) , I'd much prefer to lift the engine just enough to take the weight so I can slide it forwards onto a frame I have made to give me enough access to retrieve the saildrive from the stbd side engine access hatch. I'll need to move it forwards far more than the 3cms recommended as access isn't great to the back of the engine (probably a couple of feet I think).
I have dyneema halyards and a manual lever chain hoist. What I want to do is remove the steps, run the halyard from the top of the mast, through a block on the boom to guide it (so it will not be carrying all the weight, just the sideways force on the boom). From there I want to connect the chain hoist from the end of the halyard to the engine to then start cranking. The dry weight of the engine with the gearbox is about 250kg, so quite heavy, but nowhere near the breaking load of even normal braid on braid haylards.
Question: Should I string a chain between these two points to lift the engine or should I just lift on the back lifting point by the exhaust elbow (as that is the part that will be unsupported once the rear mount is undone).
Two lifting points:
Frame ready to slide engine on to:
Two lifting points:
