MM5AHO
Which gas is best for inflating life rafts?
Is it worth considering nitrogen rather than air as some use in tyres?
I think that they are CO2 in life rafts, not air as I said above. But why CO2? Why not N2?
CO2 will liquefy at comparatively low pressure and perhaps more important it is cheap and non flammable. In addition the heat of sublimation is comparatively low so any "icing" of the valve will not last long as the "ice" will be porous "solid" CO2. The water ice on the outside of the valve will last a lot longer.why CO2 in a life raft?
Definitely its a mix but I dont know why for certain. N2 proportion is quite low, somewhere about 5-10% if I remember correctly and I heard it's there to help expel the CO2 at the max rate. If you ever let a cylinder off by accident its quite astonishing how violently they empty (I speak from personal experience ) and quite different from letting off a CO2 fire extinguisher.I believe it's a mixture of CO2 and Nitrogen. Straight CO2 will cause the valve to freeze. No idea about the proportions.
I think it is mostly down to boiling point under pressure. Gasses like oxygen and nitrogen need very high pressures to liquefy them at room temperature. I think you'll find that industrial N2 cylinders are shipped at about 200 bar and contain compressed gas, not liquid. So you would need a cylinder with a volume of about one two-hundredth that of the liferaft tubes - a relatively large cylinder. If you use a gas that will liquefy at a manageable pressure, you can get away with a significantly smaller cylinder. Butane would work, but has obvious dangers.
Taking another angle on this, I have sometimes wondered if in extremis Co2 / dry powder fire extinguishers could be used to inflate a dinghy ( ie no liferaft available ) or would it freeze the material and cause even more problems ?
I know the powder is corrosive but I'm thinking of an urgent emergency.
Also wondered about CO2 - if a leak in a liferaft there's a chance of asphixiation. Be a shame to survive the sinking to suffocate in a leaky liferaft?
Inflation systems
Both slides and slide/rafts use a non-explosive, inert gas inflation systems. The FAA requires evacuation of the entire aircraft in 90 seconds using 50% of the available evacuation exits. To meet this, all evacuation units need to deploy in less than 10 seconds. For large, wide body aircraft such as A300s and B747s a successful deployment is complete in about 5–7 seconds, depending on conditions (such as temperature and winds).
The inflation system usually consists of a pressurized cylinder, a regulating valve, two high pressure hoses and two aspirators. The cylinder can be from 100 to about 1000 cubic inches, filled to about 3000 psi with either gaseous Nitrogen, or a mixture of gaseous CO2 and Nitrogen. Once made of steel, most cylinders now are made of aluminum or alloy cores wrapped with fiberglass, or other lightweight, fuel saving materials. The CO2 is used to slow down the rate at which the valve expends the gases.
The valve is used to mechanically meter out the gas at a rate of roughly 3 - 600 psi and 4 CFM. Typically there are two high pressure hoses attached to the valve, which are connected at the other end to aspirators. These are usually cylindrical, hollow aluminum tubes with sliding cylindrical or internal flapper doors that open when high pressure gas is applied, and close when the gas stream subsides and the internal slide back pressure reaches about 2.5 - 3.0 psi. They work on the Venturi principle, and draw outside air into the evacuation unit at a rate of about 500:1. A 750 in3 (0.43 ft3) cylinder can fill a slide with about 850 cu ft (24 m3) of air to a pressure of about 3 psi in about 4–6 seconds.
I'm surprised if they use air for aircraft escape slides, the military aircraft....
