Life Jacket Lesson
Farmer Piles
6 Oct 2020
Deepest Kernow
So; took my lifejackets down to our local chandlers', Macsalvors, open safety day to have them checked. All good apart from a couple of rusty CO2 cylinders. I bought new canisters and decided to set-off one of the rusty ones whilst wearing the jacket - never had cause to use one so thought it was a good idea.
I tugged the cord, the cylinder went off and blew the gas all over my feet. I had broken the plastic inflator housing. I don't know if the plastic had become brittle with age or if I was over zealous in how hard I pulled. End result was the same - lifejacket not inflated and unable to inflate by mouth as the air would come out of the holes in the mounting for the cylinder housing. Far from ideal if you find yourself in the sea.
Just an FYI really. For the sake of a tenner per cylinder it might be worth tugging the cord to do a test inflation rather than blowing them up. Plus a good exercise for the crew to try out and to understand what to do if they fall overboard. A bit like having a go with a fire extinguisher.
PS. When buying the new cylinders make sure that you buy the right size. mine were the 33 gm.
Bilgediver
6 Jun 2001
Scotland
I sometimes get members of our club to inflate jackets while wearing them so that they be aware of what happens and also aware it should be a hard pull on the cord not a gentle one and then stopping as soon as they hear a sound.
Refueler
13 Sep 2008
Far away from hooray henrys
Depending on the failure - you can replace housing ....
But TBH - if the jackets are old and housing has failed due to age - then prudent to cut up the old LJ and replace.
Having recently bough two auto inflate LJ's from Estonian Dealer ... new and EN-ISO rated for 50 euros total ... its a no-brainer to replace ...
simonfraser
13 Mar 2004
just cos they are new, how do you know they will inflate properly ?
Daydream believer
6 Oct 2012
Southminster, essex
I wanted to change the bottle on my wife's LJ. Before doing so, my son & I put the LJ on the wife. She flatly refused to strip off & sit in the bath :cry: but we tried any way. First she pulled the cord- zilch. On inspection we found that the cord was wrapped around the fitting. When we looked at the other 5 they were all the same.
So once sorted, she had another go.
Bang! she was looking down & one has to realise that it was not trying to ride up her body, as she was not in the bath. However, it still hit her under the chin & the seam caused a small cut enough to bleed. We told he she would have been OK in the bath, as there were no sharks,( she said randy husband was bad enough) but in the open ocean with this sharp seam rubbing under the chin, would be very painful & would draw some blood. That would attract sharks from miles away.
She decided that I would go out & buy her a different make of LJ. :unsure: 🤣
lustyd
27 Jul 2010
Good idea. But it was the failure of the housing that brought me up with a start.
Do you have a photo of the broken housing? Just curious after a convo with Refueler the other day about plastics going brittle over time in this very area.
simonfraser
13 Mar 2004
Maybe you can tell me how long is a piece of string ?
When you go out there each morning to your car - you expect it to start ? How do you know it will start ?
Silly question - same as yours TBH ...
25 euros each, i'd want to test them ....
Refueler
13 Sep 2008
Already have and they work ... so far no faults found.
Of course not having full 'textile NDT' testing - I cannot confirm or question how long they will last folded away on board ... but in comparison to my Crewsavers / Baltic and Lalizas jackets - they appear similar ..
Farmer Piles
6 Oct 2020
Deepest Kernow
Will do.
My main point really is that we all wear these safety devices on the assumption that they will inflate as they are supposed to when you are in the sh*te. You just need to know that they will, and until I tried my "trusty" lifejacket, I was under the impression that it would. As I suspect that most of us do.
As I said before, just a heads-up really.
Refueler
13 Sep 2008
Will do.
Totally agree with your posts ...
You can add another item ... just as an addition to support your stand :
How many of you lot shake and upend your Dry Powder Fire Extinguishers ?? How many just leave them in the mounts year after year and expect them to perform when called ?
I have personal experience of DP fire extinguisher only discharging a small amount of its powder as it had compacted over time in bottom of the cylinder ..
Its why on board ship - its standard to invert them regularly to prevent that occurring.
Graham376
15 Apr 2018
Local law dictates we have to have lifejackets available in tenders so, thinking they may get nicked, I bought a couple of those with Life Jacket printed on via ebay, about £29 but they come without CO2 cylinder. The trigger capsule appears non-standard so I suspect they are use once and chuck. Not much difference in price to just a rearm kit for some others on the market.
Refueler
13 Sep 2008
The trigger capsule and re-arm are available online ... so don't be too hasty to discard if ever used ! They are actually one of the standard setups .. you just have to check what bobbin size fits the auto ....
CO2 cylinders 33gr - I just ordered 4 at 9.80 quid each incl shipping.
Graham376
15 Apr 2018
Do you have a link? I couldn't find any like these -
William_H
28 Jul 2003
West Australia
The LJs I have dealt with mostly manual activation one auto. Have a schrader valve (car/bike tube like) molded into the bladder. The plastic block sits on top with a large nut holding onto the thread of the schrader valve. The plastsic block has a threaded socket for the cylinder and the actuation pin operated by a lever and cord. I have not seen any sign of deterioration of the plastic block in 15yo LJs (15 examples at club)
OP suggested he would not be able to inflate by mouth once block had failed. I think this may be wrong. The schrader valve if it has one should hold pressure without the block and mechanism. Sorry may be I am assuming all are the same but worth consideration. ol'will
