NBs
It's a lewmar 185tt used with a sidepower joystick. When I press the power buttons the little solenoids/relays click on and when I turn the rod they click as they should.
The problem is that the contactor attached to the lewmar does not click when power is pressed on from the joystick. After a few minutes with the pins on, it may suddenly click and then the propeller will work normally until it can stop working again.
I went through all the connections and no oxidation or loose connections I also put wd40 on but that did nothing. The batteries are ok too.
I wonder where the fault could be?
