Buck Turgidson
Whats the difference between zero wind and 10kts current and zero current and 10kts wind?
1) Meterologists take weather info from things which are not anchored to the groundFunny that, because all (very good) Avionics that Garmin manufacture refer to True wind as ground-referenced. Unsurprising as that's been the industry standard for about 100 years. If a marine instrument refers to True Wind as being referenced to the water it is sitting on it just means the manufacturer can't be bothered to do the necessary sums or perhaps that the system doesn't have the necessary inputs. That doesn't mean that the definition of True Wind suddenly changes though. You won't get any aircraft or system through certification if it calculates True Wind in any other way and it's a requirement that weather stations are anchored to the ground as well.
.. If a marine instrument refers to True Wind as being referenced to the water it is sitting on it just means the manufacturer can't be bothered to do the necessary sums or perhaps that the system doesn't have the necessary inputs. That doesn't mean that the definition of True Wind suddenly changes though....
It's kind of true, but you'd need NASA instruments to measure it and I mean the Cape Canaveral variety!
In practice, people who refer to Coriolis lifting on one tack are talking through their hats
Wind gradient is by comparison a very real and important concept.
No doubt someone will be along soon to strongly disagree :ambivalence:
They all use fixed earth reference!
You think i didn't read the whole document before posting?
the point is not what is more useful for sailing. The point is the use of standard terms in language. The whole point of which is the transfer of information. If i call your cat a dog is that useful?
For a boat in open water, nothing*.
Does this mean you are coming round to our side of the argument that windspeed relative to the water is a real and (to a sailor) highly relevant quantity?
*By which I mean that the experience of sailing will be precisely the same. Clearly on a given heading your ground track will be rather different.
Unfortunately it's the marine industry that is unique (if it really is the majority of sailors using this terminology and I'm not convinced as I certainly don't hear it a lot) - if anyone wants to use it that's up to them (whoever they are) but please don't pretend it's become some kind of international agreement.
No you do not. (although you are right about someone disagreeing)You just need a pole with a few wind vanes on it at varying heights.
You will soon see that for opposite tacks that you need to adjust the twist of your sail for the different angle of the wind as it changes in height
If this link works my comment about the coriolis effect can be seen quite clearly. And not actually that high either.
If you scan through the forum post they state that the pole is at the end of the bridge in San Francisco but my attempts a google do not seem to be able to find it. Perhaps others would have better luck. I have seen photos of other similar poles & they show the effect more clearly.
All without "Hi tech" gear!!!
https://www.myhanse.com/wind-direction-tower_topic11275.html
Wind shear is an important concept, but unless one has a VERY tall mast it has nothing to to with Coriolis.
The relevance to sail twist is this: the wind 15m or so above the sea will be faster than the wind blowing at sea level due to friction effects. By comparison the boat's velocity at the gooseneck and top of the mast is exactly the same.
I've often wondered how true wind is calculated by a wind instrument from speed and direction of wind and boat speed (through water) from log. There doesn't seem to be enough data.
Doesn't it also need direction of travel of the boat?It's enough to give true wind speed and direction relative to the bow of the boat.
+1
There certainly is speed gradient, and there may be direction shear in the surface layer, but not from Coriolis: usually when a different air mass layers above the other, an example is the onset of breeze in a calm day, it will be felt starting from the top of the mast, it s when one has a lot of difficulty in finding the correct twist for the sail one tack from the other
