TLouth7
I dislike the first two because "calculated" implies that it is not a real thing, and "relative" would confuse things even more. Sailing Wind on the other hand does actually describe the phenomenon, and what it is useful for. A pity it doesn't appear on any instruments though...I would call it calculated or relative or sailing.
I think you are not seeing where this Sailing Wind comes from. It is simply:Buck Turgidson said:If that were true they would all have to have exactly the same drag. Which would require them to have exactly the same crossectional area and Cd.
Ground Wind - Tidal Stream = Sailing Wind
and/or
Apparent Wind + Velocity through Water = Sailing Wind
so can be calculated either by a tactician with weather data and tidal stream atlas or by an instrument with heading, log (STW), AWA and AWS readings. These calculations will be imperfect for real vessels but that does not mean that there is not a single correct Sailing Wind at any given point in time and space.
