westernman
in which case you wouldn't have wanted to be going out anyway!
No. And I had a lot more than 2 warps out I can tell you.
But it was not as bad as the winter before.
So I would loop a bow line around a cleat on the pontoon.
You have several choices:-
2) Attach the bow line to the stern end of the pontoon. I prefer this one. In this case the ideal is to attach the line of a winch, and to motor forward against the bow line using the prop wash to keep the stern aligned. A crew member then winches the boat out of the berth a little bit at a time. Alternatively you can back out until the bows are getting dangerously close to your neighbour, the crew member quickly snatches in all the slack, takes a turn around a cleat and you motor forward against the line to put the bows back upwind. This will probably work fine in 20knots. In 30 knots you will probably be winching.
Little by little you will get the boat out of the berth under control. This is the technique we use most often when we have to..
Thanks Starfire but, how do I easily stop the bow blowing onto the adjacent boat and keep the stern from blowing off until I have sufficient way on for the rudder to bite?
Forgot to mention - really novice crew!
Cheers
The first thing I would do before getting into this situation again is to go and buy two more warps.
You shouldn't be using one line for two jobs, even though a lot of people do.
OOps sorry, just read that it's a charter boat - check the inventory before you set off, next time.
You really need to know more about a boat's close-quarters behaviour before you face such an awkward situation. As a charterer you are in a much better position to learn about it than are most own-boat sailors. Every time you take out a different boat you get the chance to learn a different behaviour pattern, but only if you deliberately set out to 'waste' some time in doing so.
I'm with Jimi on this one.... with a modern AWB that will probably drive as well backwards as forwards, a fast reverse out would be the safest option IMHO, and then let her weathercock slowly... only extra thing I would add would be to run her in reverse for a few seconds while still tied up, and then stick her back in neutral before slipping lines.... helps to get some water flowing over the rudder, and gives you a vital second or two gained before steerage is achieved....
The fast out, and then weathercock is exactly what I do, and my berth is virtually identical to the one shown in the OP's diagram, and also has a prevailing wind in the same direction too..... I do however have plenty of fenders, and make sure the stb side is as well fendered up as the port side...
Once you've got way on and have steering authority, you should have no trouble getting the stern to come around to starboard, putting the bow, not the stern into the wind by putting the helm to starboard, which will lessen, instead of exacerbating the tendency of the bow to smash into the boat next to you.
Fascinating thread.
Some poor chap asks how to get out of a marina berth and there are 50 different suggestions.
Who said sailing was easy?
Are you in the GRP repair business and looking for work???
In 20 odd knts of breeze you'll be fighting a loosing battle trying to get the bow through the wind.
You have to reverse a boat around against it's prop walk, you'll need room to get water passing over the rudder in order to do this, and for that you need space to build up speed, which you don't have.
The Bav has a shallow forefoot, and high topsides in comparison and the bow will just bow off down wind. The prop walk will exaggerate this effect by kicking the stern to port. Go with it and just reverse out of the berth and marina backwards
If you haven't watched the vid we did on prop walk it will show you what happens.
In the first 35 second you'll see why it will be easy go with the stern into the wind, the boat will swivel around in no time...you just have to remember that the boat in the vid kicks to stb
A damn sight easier than being in a berth the other side of the aisle in the same boat IMHO.....LOL! Sailing may be easy, in fact, but getting out of a marina berth with a wind blowing from your port side, another boat to starboard, and a right handed prop (port kick), is te very bitch! Hence the involved disputation.
My thoughts exactly!!
Stern boring is a well understood and used term.
Where is it used? Google doesn't seem to have heard of it. What does it mean, for that matter?
The phrase is probably derived from the verb "bear" and its past derivative "bore". The bows bore down on the hapless jimi as his crew applied reverse thrust in a desperate attempt to not run him down .
