westernman
Not something to try if short handed on this kind of boat......
It surprised me that they hoisted almost all the sails before raising the anchor.
In anything other than a dead calm, that must be very hard work.
I would have raised the anchor first, or at most had the fore and main lower topsails set.
Vessel must be "under command", i.e. have a useable means of propulsion before casting off or weighing anchor. To do otherwise would be very poor seamanship.It surprised me that they hoisted almost all the sails before raising the anchor.
Additionally we taught how to raise the anchor under sail.
I used to just haul in the anchor then once it was hanging, back the jib to turn the bow and finish hauling in as we started to make way. That was on a 23' boat though so not a massive anchor, and too lively to sit still while I got the anchor in... On a bigger boat you might have to for a moment on the tack you want to sail off on.Any tips you would care to share on how to always get the bow in the desired direction?
Use the mainsail sheeted hard in and tack.....inefficiently.....up to the anchor. Haul chain when it's slack as you sail past. Snub, tack, repeat. Surprisingly effective.Any tips you would care to share on how to always get the bow in the desired direction?
Thanks, I can see that might work, if two-handed.Use the mainsail sheeted hard in and tack.....inefficiently.....up to the anchor. Haul chain when it's slack as you sail past. Snub, tack, repeat. Surprisingly effective.
Got you. Gonna be difficult single handed without a remote control winch. Would be worth a try with a small amount of backed headsail rolled out and a scandalised main. Bit like the op video scaled down!Thanks, I can see that might work, if two-handed.
Although, I also suspect there is a risk that the boat tacks inadvertently when the anchor is broken out – which would put you on the undesired tack.
However, I was wondering more about how to avoid going in the wrong direction when single handed, that is when there is no one at the tiller.
"Sailing the anchor out"Use the mainsail sheeted hard in and tack.....inefficiently.....up to the anchor. Haul chain when it's slack as you sail past. Snub, tack, repeat. Surprisingly effective.
We leave the anchor regularly under sail when space allows. We hoist the main with the mainsheet free so the boom can swing around. Once the anchor is up I put the wheel over so the boat goes backward and turns in the desired direction. Once we are side on to the wind haul in the main and let out the jib or genoa and sheet in. No preference for which one first. Our boat will sail on just the main but not all boats willAny tips you would care to share on how to always get the bow in the desired direction?
Prefer the Solent rig to a cutterOne more reason to have a cutter! The staysail can be unrolled to give steerage way yet still leave the anchor area clear.
This is also what I do. My boat is only 3.6 t, so I haul the rode by hand. The difficulty lies in matching the natural yawing of the boat with the speed of the retrieval, so that when the anchor breaks out, the bow is on the preferred side of the wind. I have found it a bit of a gamble.We leave the anchor regularly under sail when space allows. We hoist the main with the mainsheet free so the boom can swing around.
If you can do it by hand, pull it laterally, say 1/4 fwd on one side, tension will be higher but the boat will remain on the same "tack".This is also what I do. My boat is only 3.6 t, so I haul the rode by hand. The difficulty lies in matching the natural yawing of the boat with the speed of the retrieval, so that when the anchor breaks out, the bow is on the preferred side of the wind. I have found it a bit of a gamble.
