rex_seadog
I have recently replaced the discharge hose on my old Brydon toilet with some nice new white (odour-free) stuff. The end connected to the Blakes seacock was a tight fit and had to be heated with boiling water to persuade it to fit. However, at the other end, at the elbow, it was quite a loose fit and I cannot seem to get a leak-free seal. (My old green hose never leaked). In fact with my first attempt using two jubilee clips (as recommended somewher) the water poured out when I first pumped the loo. On my second attempt I used just one clip but made sure it coincided with the two knurled (barbed or whatever the correct engineering term is?) rings near the end of the elbow. It is now better but there is still a slight weep. I have contacted Jabsco and they tell me to fit dry but as a last resort to use Silicon and not Urethane or polysulphide as it reacts adversely with the ABS plastic of the toilet elbow.
The clip is already fairly tight and I am afraid to put the spanner on it in case it cracks the elbow.
Has anyone experienced similar problems? Perhaps I should let the natural gunge act as a seal over time!!
