Leaking injector
Spyro
18 Jan 2003
Clyde
The injector on my YSB8 is leaking diesel. Engine is running fine,leak does not appear to be comming from fuel feed fitting or return fitting, Any suggestions as to the problem and how to fix
AndrewB
7 Jun 2001
Dover/Corfu
There was a thread a few months back that might help, <A target="_blank" HREF=http://www.ybw.com/cgi-bin/forums/showthreaded.pl?Cat=&Board=pbo&Number=491107>HERE</A>.
uforea
5 Nov 2001
Leics.
Ian, the injector on this engine is in two bits which are screwed together in the middle. In between there is a copper washer which acts as a seal. Either the joint is loose and simply needs tightening or the washer needs replacing.
Ted.
Spyro
18 Jan 2003
Clyde
Spot on with the copper washer seal I managed to get it sorted tonight. I removed the top banjo bolt for the fuel return pipe and managed to get about half a turn on the top part of the injector housing, put it all back together and no leak.
Thanks for advice
Ian
