Balbas
I've pulled the heat exchanger stack out of the heat exchanger. I'm sure all heat exchanger stacks are a similar design - this is a series of tubes sheathed (in copper?) and with an end cap at each end keeping the whole together. The sheathing doesn't cover the whole stack, there's about an inch at the front end of the stack where the tubes are exposed.
The whole lot was filled with muck and grunge, so I've cleaned it as effectively as I can. In doing so, I was running hot water into the tube nest - between the tubes and the sheathing. And I noticed that the sheathing has some small leaks. The tubes themselves don't appear to be leaking, just the sheathing. Am I safe to assume that this is fine and that the end cap design (together with a new o-ring) should prevent coolant water from being in this part of the heat exchanger?
Its an old Vetus M4.14 if that makes a difference.
And apologies for the numpty question. Just typing it out has helped me clarify in my own mind, but I'd like another opinion before I put it all back together.
