Miker
The toilet leaks at the seawater inlet pipe connection at the back of the toilet. The pipe connection does not appear to seat firmly against the rubber washer. I can turn the pipe connection both ways by use of brute force and a screwdriver pushed up the pipe end. I would welcome advice on how to tighten the pipe connection against the rubber washer, assuming that is the cause of the leak. Do I continue to use brute force and, if so, which way do I turn the connection?
The leak does not endanger the boat as I have fitted a vented loop. It is just a nuisance having to mop up after the toilet is used. I would add that the connection has always been like it is now. Just another example of the slipshod work carried out by the boat supplier.
