Alrob
is it not possible to run a small flat screen from the boats 12V system as I notice I have a transformer attached to 17" in my kitchen ???
I have used a 12 volt TV on board for 5 years now but the first one died very quickly. So with the second one I have used a voltage stabilizer to stop the voltage rising to much when the engine is running or mains charger is switched on.
If one is worried about voltage spikes etc and one should be! Run the set through a small inverter, then the normal transformer, saves any problems.
But at a higher current drain! Possibly 50% more.
