solent clown
RIP
I have a similar problem but it is quicker and easier to swing the boom to the side when raising or lowering the sprayhood.
Yes but you dont need the sail bag/statpack to be held up when sailing. In fact it would be better to wrap the statpack under the boom to allow the sail to set better.
Rain what rain
Being reliant on an engine for something as basic as setting sail doesn't seem a good idea to me. You ought to be able to sail off a buoy or from an anchorage without the need of an engine. Also, being able to do things under sail makes sailing more enjoyable and gives confidence.
Clearly one needs to have the skills to manouver the boat in an emergency. But if you have an engine then why not just use the ... thing & avoid any problems in a confined moorings.There would be no point having it if you did not use it
In which case you have to go on deck to do that & you have already been told that Karen wants to stay in the cockpit. - Sensible girl!!
I
Perhaps, but sailing onto a mooring or pontoon reduces my safety margin. I can do it, but I'd rather have plenty of searoom when raising or lowering sails and use the engine when parking or maneuvering at close quarters.
It may only go wrong under sail one time in 100 but, over a season, that's still too many opportunities to end up in a You Tube fail compilation for comfort![]()
well proper inboard engines are new to us and a lovely luxxury, but not being able to get the sail stright up was a bugbear. I took on board the suggestions on here, and today fitted a couple of blocks, and ran the jacklines back to a couple of cam cleats on the coachroof. Works a treat, dropping them to hoist. I still have to fit it all properly, needs an organiser block to take the lines back properly
I just eliminated the battens decades ago. No problem. Lazy bag is better, leaving your sail cover already on.
2017_06_23_11_16_23 by mark punksteel, on Flickr
2017_06_23_11_16_32 by mark punksteel, on Flickr
2017_06_23_11_16_40 by mark punksteel, on Flickr
2017_06_23_11_16_44 by mark punksteel, on FlickrThose lines do look thick. I use nylon sash window cord. Braided, cheap, effective & thick enough
May i suggest that when time comes to replace it you might find 6mm is ample. A lot less windage as well
taking a leaf from your book, I am sailing on the cheap, so redoing sails is out of the questuon when what is on there works.![]()
