Laying up Volvo with Saildrive
EdEssery
5 Sep 2001
Berks.
My boat has a Volvo 2001 with a Saildrive. I'm laying her up in a couple of weeks and want to flush and protect the cooling circuit which is raw sea water.
The problem I have is I'm not sure how to do this. There's only a very short length of flexible hose on the inlet side of the water pump and it's in a position down the side of the engine which is nigh on impossible to get to - therefore I can't easily disconnect the pipework in the engine bay and put a hose in a bucket inside the boat.
As I recall the seawater inlet is actually a grill type affair on the saildrive leg - so it's not like a normal skin fitting you can insert a hose in externally.
How do others with this configuration flush the cooling system?
Any suggestions much appreciated.
Ed
Skybird
MG C27
K8452Y
stretch33
20 Jan 2002
Essex
On my previous boat l had same set up - l used to disconnect the hose at the seacock on the leg and join a length of hose on there with a bit of pipe, think it was 15mm copper but can't be sure. Then stood bucket in saloon with hose filling it up. It was a bit awkward to get at but then its only once or twice a year. After a good flush out, run through some anti freeze solution.
I'm not sure what the leg looks like but would an outboard flushing clamp work over the grill?
Miker
30 Jun 2001
NW England
Mine's a 2010 so probably completely different. I undo the sea water filter and stuff a hose into the outlet pipe (the one into the engine). I've wound a few lengths of plastic tape around the hose to get a tight fit. Then it's water into a bucket which is sucked by the hose into the engine.
