LittleSister
Easy enough to connect to 12v and check ??
Yes, as I suggested in post #8.
That's right but that applies to any nav light yet it seems they mostly have the Fresnel sections running horizontal as in post #8.Surely you would be looking for maximum vertical - to allow for pitching ?? ... but limited to cut-off angles horizontal ?
I am familiar with Fresnel lenses, linear and circular but your final point, are you suggesting that I have multiple accounts?Post #8 misunderstood what a fresnel lens is, and described a specific type. They are actually just flat lenses and can work in pretty much any way a normal lens does just with less material and thickness.
You might want to delete one of your accounts, it’s confusing when you reply from different personas, and breaks forum rules.
Well, you’re (S04) talking as if you’re the OP (SteveIOW). If not then apologies and good of you to raise a support ticket on his behalf.I am familiar with Fresnel lenses, linear and circular but your final point, are you suggesting that I have multiple accounts?
The buyer will know who the seller was.It’s unclear who that is, since Lalizas don’t list it. If it was a nav light, it should have certification available to view.
The details are in COLREGS annex I. Also intensity, horizontal sectors, and position. It is interesting to note that powerboat lights do not meet the same requirements are sailboat lights, because of heeling. Anchor lights, obviously, are the same, since you are not underway. The same could be argued for a steaming light. Side lights are the main difference.
10. Vertical sectors
(a) The vertical sectors of electric lights as fitted, with the exception of lights
on sailing vessels underway shall ensure that:
(i) at least the required minimum intensity is maintained at all angles
from 5 degrees above to 5 degrees below the horizontal;
(ii) at least 60 percent of the required minimum intensity is maintained
from 7.5 degrees above to 7.5 degrees below the horizontal.
(b) In the case of sailing vessels underway the vertical sectors of electric
lights as fitted shall ensure that:
(ii) at least 50 percent of the required minimum intensity is maintained
from 25 degrees above to 25 degrees below the horizontal.
(c) In the case of lights other than electric these specifications shall be met
as closely as possible.
No, only the spec sheet will do that.So this bit confirms the fresnel elements should run horizontally?
That makes sense yes. I was just musing, making an observation. I wasn't trying to be contentious.Doesn't the form and direction of the lens depend on the light source that is behind it ?
I'd only use it in a wet locker for light.
No use what so ever as a nav light.
I've now had a reply to my enquiry with the manufacturer:I did that a few days ago and received an automated ticket number but I'm not expecting a proper response until early in the new year.
Dear Chris,
Thank you for contacting Lalizas Support.
The ideal way of installation is with the screws in a vertical orientation (top-to-bottom).
Please let us know if you need any further information.
Best regards,
Argyrios Parianos
Procurement Dept.
Your LALIZAS Team,
