Jeepster
I made up a system with Seapro Lite, which I think supports AIS. I got an ancient laptop and buried away (in a cool place) so it was protected from vibration etc....... then connected a nice big monitor and used a wireless keyboard and trackball. Worked a treat and never let me down. It was all powered from the boat batteries as invertors are not ideal. Having said that, if you must have 240v then that's the only option, but you can often dispense with the laptop power adapter and wire it straight into the 12v, assuming obviously it's a 12v laptop and monitor.
I am a newbe to all this electronic navigation malarky and I have to say I've learnt loads just reading the first page of this thread. I had never heard of AIS before...Did a wesearch and was pleasently supprised to find I can now see where the big ships are at a stroke...Brilliant!
Also I had no idea Maplins did GPS dongles for £20 or what you could do with them...I will certainly have to look into that.
I have a question to ask though and to save me trudging through every single reply in this thread to find the answer I'll ask the question here...I wonder if there is some kind of in-line automatic voltage regulator available to allow me to run equipment requiring a 12v supply safely from the DC supply from the boats single main lead acid battery, when it could be being charged by the engine at up to 16v?
The fear of the high charging voltage frying delicate and often expensive electronic items is always at the back of my mind, so any solutions that are'nt too expensive would be very welcome...Apart from the basic resistor- on-a-heatsink way to drop the voltage, any better ideas or off the peg solutions?
Can a 12v inverter run at up to 16v input safely?
I have a 24v inverter too but 16v would probably be too low a voltage to power it.
