MapisM
As per title - can anyone recommend a good one?
Tx in advance!
Tx in advance!
Tx in advance!
Sorry, wazzat? Never heard of it.I have always used CAT sampling packs, good reliable service and I can log in and check past results as well
I have used The oil lab a couple of times, the service has been quick and efficient. www.theoillab.co.uk/
Tx in advance!
I was told by my surveyor that if the engine oil had very recently been changed analysis would not be useful. How true that is I don't know but it seems to make sence.
Yes and no.Yep clearly correct
Yes and no.
Sure, it doesn't make sense to throw in fresh oil, run the engine for 10 minutes and then test a sample.
But oil analysis is mostly about the film, not the single picture - i.e. keeping the nasties development monitored over time.
A "fresh oil" test, made after 5 to 10 hours, is very useful for two reasons:
1) if the oil would be already contaminated after such short period (which is indeed possible!), that would be VERY interesting to know;
2) if it's still ok after the initial run-in (as it should), it will still be interesting to compare the numbers with a future analysis, to be made after 100 to 150 hours.
Thanks folks, useful stuff.
@Anders: why are you saying "depending on where you're based"?
See, the reason for my question is that in the past I used a big lab which recently decided it wasn't worth offering this service anymore, their core business being with more sophisticated industrial chemicals.
And aside from being top notch, it was near to my home, so I could just drive there and bring them the samples.
But I would have thought that it isn't a problem (other than sealing well the bottle of course) to send small samples anywhere by courier, at least within EU.
Or is it? Are there any restrictions for shipping oil maybe?
Aha, I didn't realise that before posting my question.But they're based in USA, so it might make sense to use a more local company if you're based in Europe.
