tudorsailor
It is some years since I did a knee replacemen as I have become an upper limb surgeon. However I would make the following comments
All operations have risks of complications and even death. TKR is no different. The decision to go ahead should be based on pain and not stiffness. If the pain is severe and your life is ruined by it then it is worth the risk
There is no special TKR privately that is not available on the NHS
Kneeling is a problem after a TKR as one does not usually achieve full flexion. THis is a problem for those who kneel to pray and need to be forwarned
TKR implant survival is at least as good as THR
TKR does not have the risk of dislocation as a THR when the hip is flexed maximally (and this scared me silly when I had a guest on board who had a THR and kept bending down. My prayer for her not to dislocate the hip while on my boat seemed to work)
TKR has a much lower risk of peri-prosthetic fracture than a THR ie fracture of the bone in which it is implanted
A joint replacement is not the same as changing a gearbox. It is not something that can be repeated at will if there is a problem. A revision is a different kettle of fish.
So if you really need a replacement, then have one, while accepting the small but real risks.
If your symptoms are not too bad and think that you might as well have a replacement sooner rather than later, do not have surgery.
TudorSailor
TudorSailor
