fisherman
I wonder sometimes if anyone apreciates the trials we used to go through with engines in the past. (Reading the thread on Stuart Turners on PBO)
The first Kelvin I came across was a first war vintage single cylinder heavy duty eight. A tall machine with a 'diver's helmet' exhaust mixer on top, an immense stroke and many starting handles: we soon found out why. When it first fired it would throw the handle round and due to the cramped engine space it would hit you on the temple, whereupon you would throw the handle over the side. It was stopped by taking off the plug lead, and whoever was sent below to do so would yell out from the jolt, to get the reply: " What's wrong with you, you want to live for ever?"
Next came a 'Poppet' 12/14, petrol/TVO, which could be started turning the flywheel by hand: only found this out when I was painting the flywheel rim one day........It had a row of decompressors and you could play crazy latin-american rhythms opening them in time.
Then a 1936, 30hp Ricardo. It ran on petrol, TVO and only two of its four cylinders (due to a warped head). It was a riot of leaks, squeaks and mysterious intermittent booming noises. About every hour it would start missing and I had to dive below, change over to petrol, open the decompressor taps, and after a few moments of popping and banging and spouting flames at the deckhead it would pick up a regular beat again.
When I finally made the regular acquaintance of a diesel engine I was astonished to find it would run all day without attention.
Don't know you're born you lot......
