Keeping the salt dry.
fredrussell
24 Mar 2015
So. Down to serious issues after all the frivolous nonsense about distress flares, anchors and exploding batteries.
What devices are you all using to keep the salt dry? I seek something that allows quick access (ie flip up lid) rather than having to unscrew a lid each time. Googled it but just wanted to check I didn’t miss something obvious people are using. Must be waterproof or at least air-tight.
…and before anyone says it, it’s not a ‘first world problem’ as I live in Suffolk.
We use the salt mills from Aldidl. They have a cap, and the bigger grains mean they tend not to clog as readily. It stays on board when we're using the boat regularly, but if there's likely to be a longer gap, we have a bag in which tea, coffee, salt, pepper and other stuff that doesn't keep well in higher humidity, and it comes home with us.
I used table salt that comes in the plastic containers with a flip lid for cooking. The boat was fairly dry. Sometimes the salt would clump up, but a decent shake of the container would loosen it up enough to pour. The salt is cheap enough to replace each year if required.
The other salt I use over food is sea salt, in a plastic container with a airtight lid. Keeps well, though again if it seems to clump up a good shake of the container sorts it out.
I leave this on board during the winter rather than taking back and forwards all the time.
Table salt contains anti-caking agents to prevent it clumping together in moist conditions.
I use two methods. One is a salt grinder. The other is a hand pumping tap directly into an unlimited reservoir of a salted brine for cooking with. Only use the latter when in underway or appropriate anchorages.
