burgundyben
The boat is a 1963 Fairey Huntress, she has been sat on a trailer for 18 years, the method of supporting the boat was complete wrong, all the weight on the centreline where in fact the factory drawings show that they should be supported by thwartship bunks out to the chines.
The hull is a single hot moulded shell, 6 layers of 2.5mm thick veneer stapled down to a buck and backed off in an autoclave, the buck had a slot in it along the centreline, into that slot was fitted a piece of mahogany with a pair of bevels to the top (bottom when boat right way up) was fair for the veneers to sit on.
This boat has been twin outdrives, then a surface drive, then mid 90's was converted to shaft, close to the Navy spec layout, albeit with a thicker shaft and consequently a thicker tube.
I need to work out how to chop out, make up a new piece, glue and screw, then bore a new shaft hole.
