meldrum
I am currently doing a major refit on my YM MG waterwitch, she was built by hartwells in plymouth in 1964 and appeared at that years boatshow, as far as I know the keel bolts have never been replaced and as the nuts are now more mushroom than nut I thought it would be a good idea to replace them, there is also some rust streaking emanating from the keel deadwood joint. I am confident of doing the job and my next task is to remove one of the bolts to check it. What I would like to know is, (bearing in mind the fact that she has a long iron shallow draft keel approx 10 ft long, the hull despite being plywood is in sound condition ,a tribute to her builders who sheathed the hull with cascover sheathing, obviously not a friday job), Is if the hull is suspended by the strops of the boat lift aft and forard of the keel, would the deadwood be strong enogh to support her weight whilst the keel is removed. PS I intend to remove the keel bolts before lifting and replace five of them with 12mm threaded bar equipped with ball races and lower the keel using these once the she is suspended in the strops of the boat lift. or would it be best to remove the bolts from the keel before hand and just lift the boat away from the keel. (as it is only a shallow square section keel removing the bolts would have no significance regarding her stability whilst propped.
Thanks chaps for you assistance regarding my post about mcb,s (the reason i asked was i have access to a large quantity of these for nothing and anything to save money.
