dtynan
I'm looking at a Hallberg Rassy which seems to have a leak in the fuel tank. The one in the keel. I haven't actually seen the boat yet, so consider this pre-research!
Apparently the leak is about a quarter of the way up, so the tank is good for 30 litres. The first thing that makes me wonder is how did a leak form in the tank at that spot? Was it a hard grounding, or is there corrosion right through and this is the first place where the corrosion has gone right through the tank wall or seam?
More importantly, exactly how hellish of a job is it to remove the tank? The engine would definitely have to come out, and I seem to recall that 'Rassy's have a fibreglass cover over the top of the tank. It might be easier to open up the keel around where the leak is, unless (as per point #1), this is the first leak to make its way through the tank wall, and many more will follow.
I guess I could just isolate that tank completely, and switch to the 90L tank instead, but it seems a shame to lose 150L of fuel capacity.
Has anyone done this? Lifted the tank out for repair/replacement?
