boatingalex
I have a kad 44 that will run well for a hour or so then when in rev range between 1500 and 2000rpm engine will come out of gear and drop rpm to around 1000rpm. But more recently the engine will just die then won't restart until the following day when cold.
i have already
Batteries drop tested
switched throttle potentiometer
shift actuators switched between engines, fuel filters changed and cleaned.
Big square plug cleaned and put back together.
Could it be the ecu fuel cooler? Thanks in advance
i have already
