Peppermint
Just when you thought you\'d got the hang of it.
I’ve always felt bad that I wasn’t certain with my tidal calculations in Southampton Water. Not any more.
I have a tidal curve for Dock Head on 1st & 2nd of February 2004. High water should have happened at around 1900hrs but it arrived a little early and about 50cm over estimate. For the next hour and a half it dropped like a stone. From a little over 4.00m to around 2.80m. In the next hour it climbed about a metre before dropping to about 10cm below the 2.00m predicted low water at about 01:30hrs The next flood had a similar profile gaining about a meter in an hour and a half before dropping back and then starting again.
When you consider that many visiting ships work with 1:00m clearance under keel you’ll appreciate that the pilots & VTS were scratching their heads a bit over this one.
