Madhatter
I am looking at a Junk rigged boat 22' ,I would love to know what the panel think of this set up ?
Things have changed over the last few years - there are now proven methods of incorporating camber into junk sails - either by using hinged battens, or the inclusion of rounding into each panel. The resulting windward performance is now quite good.I used to make the sails for junk rigged Kingfishers. The sails could be made of just about any material by anyone as they have no shape cut into them.
The only downside was windward performance, which was about the same as an old gaffer in both speed, pointing ability and leeway.
There was one in the RTI in june, We passed it on the run down to the needles, half way to St Catherines Point he was back along side us.Things have changed over the last few years - there are now proven methods of incorporating camber into junk sails - either by using hinged battens, or the inclusion of rounding into each panel. The resulting windward performance is now quite good.
Junk is a very simple, low stressed, low tuned rig. That's to it's advantage and disadvantage.
I've sailed many hundreds of miles in one, and alongside many others. They TEND to have modest upwind performance. You CAN get round the performance shortcomings, but only by sacrificing a good deal of the simplicity and low tuning, which, to my mind at least, is a major part of the rationale of a junk.
Assuming you haven't go hinged battens and goodness knows what else -
Some Advantages - ultra fast, easy reefing; because of speed/ease of reefing it's easy to carry plenty of sail for light airs in your standard sails; low stress means usually no need for winches; very simple, almost anything in the rig can be made or repaired by hand yourself or by any reasonbly handy person anywhere in the world with simple materials (no need for fancy proprietary kit or waiting for parts to arrive); low tuned rig means very forgiving in terms of trim; great downwind as position of sail not limited by the mast stays (you can even safely run by the lee).
Some Disadvantages: Miles of rope (sheets) to deal with; modest upwind ability (see above); limited ability to tune rig; no mast stays to hang on to going forward!
A great rig for laid back cruising, in my opinion, and particulary for (world) cruising on a budget.
A complex, chafe prone rig which is hopeless to windward. Camber only works on one tack. OK for a 22 footer, not much to lose, but a big mistake on bigger boats.
