Jump leads warning
zoidberg
12 Nov 2016
I attempted a jump-start on the ould car the other day, using a new set of ( Chinese? ) jump leads.
'There's no smoke without fire...'
On later inspection, it appears that the 4 crimps had been badly made, with fine-strand wired doubled back over still-insulated cable then inserted and 'crimped'. Poor/loose electrical crimp-connections resulted IMO in immediate overheating, smoke then flames.
Perhaps others might care to inspect/check their own jumpleads?
They look cheap and nasty. Corroded from laying in damp? May be suitable for small petrol engine, but diesels requiring prolonged crank at high load need much better leads than that. Just guessing.
No surprise there! It's always tempting to buy a 'bargain', and they're only for occasional use, aren't they :unsure: . I guess you're already looking for a better quality replaqcement?
After connecting the jump leads I usually leave the good engine running for a few minutes to put some charge into the bad battery. The jump leads then pass much less current when operating the starter. I have got away with some really flimsy jump leads by doing this.
They certainly look 'nasty' now! And they were new, clean, kept in the original sealed plastic bag and inside a fabric bag in the boot.
Me too: For many years I carried a really LONGGGGG set of jump leads made from (probably) 10mm cable and as long as you ran the charging engine for 2-3 mins the wires might get a bit warm but it would always start the other car when required. Also used them to start another boat's big diesel once when moored alongside, though on that occasion I gave it 10 minutes charging.
Long jump leads often surprisingly useful in the days before lithium charge packs.
Had a similar looking set that the clamp fell of from last summer. On inspection the conductor was tiny (~2.5mm / similar to mains twin and earth) vs the thickness of the insulation, luckily no smoke etc, but it explained why they didn't work very well when needed! In the bin an d anew thicker set (verified conductor thickness / cross section) obtained to replace them.
Not new or unique to Chinese. My first experience with bad jumpers was 50 years ago. Often the wire is good, and the first thing you should do when you buy them is check the crimps.
I bought some cheap welding leads a year ago. Fine, except for bad crimps. I replaced them with bolt clamps, no more problems. 150 amps. The wire is very good and the electrode clamp is good. The ground clamp was crap, so I bought a standard one from Hobart.
There's some absolute rubbish out there.
I recently bought a set from Amazon, reviews were good, they looked fine when they arrived.
When I went to use them, one of the crocodile clips fell off, because it hadn't been crimped at all. This revealed a very small wire inside the deceptively thick insulation.
So that was a waste of a tenner...
Absolutely. I grew up with unreliable old bangers in the 1970s. A can of Holts Easy Start and some jump leads that you later find had aluminium conductors, not copper. In those days "Made in Hong Kong" meant cheap.
