single
Job today involves unblocking a Jabsco manual bog that has not been used for about a year so i imagine it will stink.What tools and cleaning stuff should i take.Is it right not to use domestos or similar in it?
It has been said many times before.....
Buy a new one. About £60.
Unblock at home at you leisure.
I would [buy a new Jabsco] but seacock is jammed so would need boat out to add to cost so fix it where it is for now.
The most common thing that was said to me at the time was don't put anything down it unless its been eaten first and this is now our rule too .
I tried using the seal kit on an old toilet and ended up buying the whole pump which I should have done in the first place.
I did buy a new pump when the old one became very stiff. After replacing the pump, I had a close look at the old one. In the end, all that was needed was a smear of vaseline round the o-ring of the piston.
I now have two pumps, both working smoothly.
