jabsco pump---noisy
clyst
18 Aug 2002
Just up-graded my domestic cold water from a foot pump to pressurised by using a jabsco auto pressure pump . I'm disappointed to say the least /forums/images/graemlins/frown.gif. The bloody pump is very noisy and pulsates continually whilst in use . Has anyone used this type of pump ?? Are they renowned to be noisy?? Maybe it a poor installation --- any ideas anyone ????
Cheers
Terry
Gregy
25 May 2007
they do tend to make a bit of noise, I've just delivered a 1.2 million Oyster 56 and the pump systems pulsate throughout the boat !!! the options from an engineering view point would be to mount on cotton reel rubbers, this might help regards Greg
donm
17 Jul 2005
Bristol Channel
I also put one in this Winter and it whirrs a little but does not pulsate. I mounted it on rubber feet to reduce the possibility of sound transmission.
Try some sound deadening/absorbing material around or adjacent to the pump. Even a little carpet will help to absorb the sound.
billskip
6 Sep 2001
Good advise to mount on rubbers /forums/images/graemlins/smile.gif but also, if connected direct to solid pipe, try putting a short flexible pipe between pump and solid pipe
Dipper
30 May 2001
Dorset
The pulsation can be evened out by fitting an accumulator tank in the system such as this:
Frontier
11 May 2005
Oxfordshire, England
Maybe there is a flow adjustment. I have a Flojet and it has a tiny screw to adjust inside a cover on the end. It so you can set the sense point so it knows to stop (and start )
awol
4 Jan 2005
Me - Edinburgh; Boat - in the west
The noise has its advantages. It discourages (and advertises) water wastage and I rather like mine. Just remember to turn it off at nights otherwise the occasional pressure top-up can be annoying, especially for the one whose bunk the pump is under.
RMA
27 Mar 2003
Essex
I had an old Par which was noisy so I installed a Whale which was just as bad. I mounted it on rubber but it didn’t make much difference. At least you know if someone has left the tap on.
clyst
18 Aug 2002
Thanks for all your replies chaps . Guess I'm stuck with it then . Wish I knew about the noise though the Mrs is n't going to be happy !!!!
/forums/images/graemlins/laugh.gif I dont know why I 'm making a joke of it I'm in deep doo doo . /forums/images/graemlins/frown.gif
Cheers
Terry
