Elissaar
Dear All
I wonder if you can help on what is hardly an eye catching subject. Having spent the last month with my head in the cockpit locker fixing a leak in the hot water system (split pipe) it dawns on me that the cooling water hoses for the engine should probably be renewed (uses a larger diameter but same hose type).
Current hoses (as fitted by Najad 7 years ago) are clear (well they used to be!), PVC hose with a metal coil embedded in the wall. Vetus do it this stuff for £2 a metre (would need about 10 metres) and its designed for pressure water systems. However, the fact that a hose in the water system split is making me think I better think of replacing the stuff for the engine (it might be important). What should I replace it with, the same or something more substantial? The engine is indirectly cooled with sea water (its an MD2030). What do poeple usually use that can go round bends without collapsing.
Sorry I tried to make it short and witty but have failed.
Simon
Simon
