Seven Spades
If you are “sleeping” on your boat then that is where you risk being in breach of the law. Under the Regulations a person cannot be “...outside of the place where they are living without a reasonable excuse”.
The reasonable excuse that the government appear to believe allows boating and sailing is the new paragraph 6(2)(ba) “...to visit a public open space for the purpose of open air recreation....” as this is the change which has led to the specific guidance allowing boating and sailing. Arguably the reasonable excuse under paragraph 6(2)(b) - “exercise” - could also apply. However, if you are “asleep” on your boat it is difficult to see how you argue that you were engaging in exercise!
So, would sleeping on your boat afford you a reasonable excuse under 6(2)(ab)? Well, the government guidance says not, but as rightly pointed out it is only ‘guidance’ and not legally enforceable - although a court is likely to be guided in their decision as to whether your actions were lawful and their interpretation of the legislation by the government guidance (and particularly a lay bench sitting in the magistrates’ court). Personally, I think one issue that could be important is the place your boat is located when you are sleeping. If you are in a marina then it will be more difficult to argue that you are visiting a “public open space for the purpose of recreation”. That is because the interpretation of “public open space” for 6(2)(ab) is found under Regulation 6(5) and in particular is defined as a place “...used for the purpose of recreation by members of the public”. I suspect a court will interpret a marina as more akin to a caravan park and primarily as a place to keep your boat and not a place that is used for the purpose of recreation. However, if you were anchored in a bay, then there is a much stronger argument that you are in a place “used for the purpose of recreation” and which you are “visiting” for “open air recreation to promote you physical and mental health or emotional well-being”.
Therefore, if you are planning on staying on your boat, do it at anchor somewhere pretty, which may afford a defence under the Regulations, but at the very least will make it more difficult for PC Plod to coming knocking on your cabin door !
I broadly do not disagree agree with this assessment. I did say "Anchoring is a normal boating activity so is picking up a mooring". I think the fact that the guidance says "all forms of water sports practiced on open waterways, including sailing..." is pretty clear it isn't qualified. Staying in your own marina is pushing it, but visiting a marina should in fact be permitted, but marinas are entitled to make their own rules.
